blender3d.cz http://www.blender3d.cz/forum/ |
LODa Pydoc http://www.blender3d.cz/forum/viewtopic.php?f=11&t=461 |
Autor: | jm [ ned lis 21, 2004 2:54 pm ] |
Předmět příspěvku: | LODa Pydoc |
cau tohle by vas mohlo zajimat, poradil mi ten link Vilda , dik http://projects.blender.org/viewcvs/vie ... er#dirlist -------------------------------------- Kód: # $Id: KX_SCA_ReplaceMeshActuator.py,v 1.3 2004/09/19 01:33:08 kester Exp $
# Documentation for KX_SCA_ReplaceMeshActuator from SCA_IActuator import * class KX_SCA_ReplaceMeshActuator(SCA_IActuator): """ Edit Object actuator, in Replace Mesh mode. Example:: # Level-of-detail # Switch a game object's mesh based on its depth in the camera view. # +----------+ +-----------+ +-------------------------------------+ # | Always +-----+ Python +-----+ Edit Object (Replace Mesh) LOD.Mesh | # +----------+ +-----------+ +-------------------------------------+ import GameLogic # List detail meshes here # Mesh (name, near, far) # Meshes overlap so that they don't 'pop' when on the edge of the distance. meshes = ((".Hi", 0.0, -20.0), (".Med", -15.0, -50.0), (".Lo", -40.0, -100.0) ) co = GameLogic.getCurrentController() obj = co.getOwner() act = co.getActuator("LOD." + obj.getName()) cam = GameLogic.getCurrentScene().active_camera def Depth(pos, plane): return pos[0]*plane[0] + pos[1]*plane[1] + pos[2]*plane[2] + plane[3] # Depth is negative and decreasing further from the camera depth = Depth(obj.position, cam.world_to_camera[2]) newmesh = None curmesh = None # Find the lowest detail mesh for depth for mesh in meshes: if depth < mesh[1] and depth > mesh[2]: newmesh = mesh if "ME" + obj.getName() + mesh[0] == act.getMesh(): curmesh = mesh if newmesh != None and "ME" + obj.getName() + newmesh[0] != act.getMesh(): # The mesh is a different mesh - switch it. # Check the current mesh is not a better fit. if curmesh == None or curmesh[1] < depth or curmesh[2] > depth: act.setMesh(obj.getName() + newmesh[0]) GameLogic.addActiveActuator(act, True) @warning: Replace mesh actuators will be ignored if at game start, the named mesh doesn't exist. This will generate a warning in the console: C{ERROR: GameObject I{OBName} ReplaceMeshActuator I{ActuatorName} without object} """ def setMesh(name): """ Sets the name of the mesh that will replace the current one. @type name: string """ def getMesh(): """ Returns the name of the mesh that will replace the current one. Returns None if no mesh has been scheduled to be added. @rtype: string |
